400 Kat clocks?
gregwgsxr
Been thanked: 3 times
400 Kat clocks?
Post by gregwgsxr » Wed Jan 23, 2019 8:34 pm
So with a 1200 bandit engine in the 400 Kat the clocks wont be up to the task the speedo needle will be bending as i push past 120mph + the question is can it be re-calibrated and have a new face popped on it?
Or has anyone a set of clocks with a better mph range?
Ta
The only thing to fear is fear itself!
1050 Speed triple
XS650/750 flat tracker
TT600re
748 sps
916 biposto
916 with an sp engine
400 Katana project (1200 Bandit!)
Re: 400 Kat clocks?
Post by fossie » Wed Jan 23, 2019 11:20 pm
An easy answer is the in line cable adapt ears which turn km in mph.
Depends on where the speedo drive will come from, blue for front wheel and gold from gearbox.
Re: 400 Kat clocks?
Post by johnr » Thu Jan 24, 2019 12:51 am
yup, kph adaptor makes good sense, 180kph clocks become 180mph clocks and also the rev counter is better considering that the bandit has a higher redline than the stock kat and is closer to the 400 redline.
gregwgsxr
Re: 400 Kat clocks?
Post by gregwgsxr » Sun Jan 27, 2019 8:48 pm
It will be fine bit of welding jobs a good un, already placed it in the frame it fits.
Can only have one coat of paint on the frame though as its a bit tight!
1050 Speed triple
TT600re
748 sps
916 biposto
Re: 400 Kat clocks?
Post by johnr » Wed Jan 30, 2019 2:37 am
gsxr1100 engine in a kat400 frame has been done before by another club member.
gregwgsxr
Re: 400 Kat clocks?
Post by gregwgsxr » Wed Jan 30, 2019 8:10 am
Yes but who is he still around? Step forward i may have questions!
But i have the 1200 bandit engine now just waiting for a sand blasted frame to come back, then i can start the welding.
1050 Speed triple
TT600re
748 sps
916 biposto
gregwgsxr
Re: 400 Kat clocks?
Post by gregwgsxr » Wed Jan 30, 2019 2:55 pm
Did he get the project on the road in 2010? :)
1050 Speed triple
TT600re
748 sps
916 biposto
gregwgsxr
Re: 400 Kat clocks?
Post by gregwgsxr » Wed Jan 30, 2019 3:13 pm
Ah he survived then! :) yeh nothing will just fit, all the engine mounting lugs have been cut off ready for new ones, the tank will need to have a chunk taken out of it and probable numerous other little bits. But i may be able to use engine mounts and frame rails off the 1200 Bandit.
All sounds a bit Frankenstein but it should be on the road for summer.
1050 Speed triple
TT600re
748 sps
916 biposto
Re: 400 Kat clocks?
Post by johnr » Wed Jan 30, 2019 10:50 pm
harry hawkins (to be said in a dick van dyke in mary poppins cockerneey accent) was thee man with th gsxr/kat hybrid.
