Switches
Switches
Post by PaulD » Thu Apr 12, 2018 12:07 pm
Do the switches in the side panel contain a relay? I’ve bought some small daylight running lights which I’m going to fit under the beak.
Re: Switches
Post by Kryten » Thu Apr 12, 2018 2:32 pm
Hi Paul. Switches on the side panel are just that; latching switches, although some appear to be momentary as the tags inside break.
They were intended to switch ancillary equipment with power sourced from the 0 and 12 volt terminals at the bottom of the fuse block.
Re: Switches
Post by Uncle Bob » Thu Apr 12, 2018 6:29 pm
I haven't seen that little circuit diagram before - that's interesting - I did wonder where the easiest place to take the power from was for those switches.
Re: Switches
Post by fossie » Thu Apr 12, 2018 8:18 pm
Paul I assume that you intend to use the daytime lights instead of headlamp, I would advise that keep the headlamp on all th time to avoid reg/ rec problems.
Re: Switches
Post by PaulD » Fri Apr 13, 2018 3:44 am
fossie wrote:Paul I assume that you intend to use the daytime lights instead of headlamp, I would advise that keep the headlamp on all th time to avoid reg/ rec problems.
Ah, I thought that lurking in the back of my mind somewhere was something about reg/rect problems with Suzuki’s of a certain age :oops: thanks for that boss.
As all the bikes I’ve had for a good while now have been old Japs I never use the lights during daytime for fear of a flat battery plus Pussy’s battery isn’t brilliant :cry:
I had one of those “sorry I didn’t see you” moments the other day (thank gawd I’ve sorted the brakes out) which got me thinking about daytime lights as I point blank refuse to wear hi vis clothing :lol:
I must invest in a Motobatt dry battery as recommended by my water cooled two stroke Suzuki riding friends.
Yet again my membership of the KOC has saved me valuable beer tokens.
Re: Switches
Post by fossie » Fri Apr 13, 2018 7:38 am
Completely with you re hi viz ......HOW CAN IT BE HIGHLY VISIBLE ? IT IS EITHER VISIBLE ...OR NOT,!!!
If they can't see your headlamp they won't see a yellow jacket that every man and his dog(literally) in some cases wears!
Re: Switches
Post by Kryten » Fri Apr 13, 2018 9:18 am
Hi Paul,
As an extra to this, the power source terminals are permanently live, so you may need to replace the battery if you keep forgetting to switch off the lights. :lol:
It would be fairly straight forward to tie in your LEDs to the parking light feed. Make up a little sub-loom to the LEDs so you can remove the fairing easily.
As for the Reg/Rec issue, the most common mod is to loop the switched phase from the alternator directly to the Reg/Rec as the other 2 phases are. This means that the alternator is not running with unbalanced phases.
The original colours of the 3rd phase wires are White/Green from the alternator to the switch and White/Red from the switch to the Reg/Rec. Of course if you have a replacement alternator then the wires could well be different such as all yellow. If you have the Honad CB250/400 Reg then that's a different mod that is documented on here somewhere.
Re: Switches
Post by PaulD » Fri Apr 13, 2018 4:48 pm
Hi Jim, thanks for that but you lost me at permanently live :lol:
This electrickery is black magic to me. The extent of my electrical knowledge stops at if I press the starter button & nowt happens the battery is usually flat :oops:
Thanks anyway, Paul
Re: Switches
Post by johnr » Fri Apr 13, 2018 5:01 pm
if you want a brighter light but not headlight, you can buy quite high powered led sidelight bulbs that simply replace the existing sidelight bulb.
Re: Switches
Post by PaulD » Sat Apr 14, 2018 6:30 am
johnr wrote:if you want a brighter light but not headlight, you can buy quite high powered led sidelight bulbs that simply replace the existing sidelight bulb.
Thanks John but I don’t think my Kat has a sidelight fitted?
The right hand light switch is just on/off and then the left gives high/low beam. I think my bike was an Italian import so maybe that explains it?
