The hole keeps getting deeper.....
Hi all,
It seems the further i look into the condition of my 750s3 engine, the more of a nightmare it becomes!
Im am now in need of some serious help!
My valves are shot!!!! This explains the terrible compression.
The inlet valves are badly pitted and the exhaust valve heads are bent?!
Would anyone out the please be able to help me out with some valves?? I really want to be able to ride this season....
Many thanks in advance!
Sent from my SM-G930F using Tapatalk
- Has thanked: 128 times
- Been thanked: 269 times
Re: The hole keeps getting deeper.....
Would be worth looking for another engine to donate parts if the bottom end is good.
This bloke might be worth a ring as he has 3 engines, one of which is an actual Pop Up engine, but he says he has sold the cam followers out of it..
http://www.ebay.co.uk/itm/Suzuki-GSX-75 ... Swm8VU03Gq
Thanks Kryten! I'll see if he is willing to remove the valves. Im only in need of Exhaust valves now
Update: the guy has valves but he said it isnt worth his effort to see if they are ok and send them to me...... excellent seller!
- Has thanked: 187 times
- Been thanked: 738 times
Loads of valves for about £17 and postage from states. But in some cases no much ....search for GS700 ES
same part number as 750 , just piston size different for certain US states.
- Been thanked: 343 times
are they different valves to the other 750 kat engines or are they specific to the pop up/es engine? if they are the same, im sure someone in the club will have 750 valves. i have a full set, but thyre still in my coffee table.......lol.
I looked up other Gsx750 Engines and they seem to be different....
What milage has your coffee table got on it?
my coffee table is the wrong sort of gsx750 but i was wondering if the part numbers for the valves might be the same, but i dont have a microfiche to hand.
Sheesh!KatanaBob wrote:Update: the guy has valves but he said it isnt worth his effort to see if they are ok and send them to me...... excellent seller!
Ok how about this one:
http://www.ebay.co.uk/itm/Suzuki-GSX750 ... SwpkFY473O
You might have to buy the complete head and strip and swap about the bits yourself. He says the engine was an R703~~ so should be the same as the Pop Up donkey.
