who wanted a lighter clutch?
Post by johnr » Mon Dec 12, 2016 8:19 pm
theres been a few posts in recent years wondering about making the clutch lighter on the 1100 kat, many of them were lost when the forum fell over, but there were various ideas about making up hydraulic conversions or attempting to find the unfindable (final edition electric servo clutch) anyhow, ive just found these. theyre hydraulic convertors for cable clutches and screw into the place where the lower cable adjuster bolt/screw lives, for the price theyre listed at, ive ordered one to see how they fit, what do you think?
http://www.ebay.co.uk/itm/401141348066? ... EBIDX%3AIT
Has thanked: 143 times
Re: who wanted a lighter clutch?
Post by Nicky Dodds » Mon Dec 12, 2016 8:42 pm
Should it work then it would eliminate all the friction generated by routing cables round bends etc making it smoother as well as lighter. No more lubricating or frayed cables.
Post by johnr » Mon Dec 12, 2016 9:02 pm
and depending on the bore of the master cylinder, this has the potential to make for a very light clutch indeed.
ive ordered a black and a silver one.
Post by fossie » Mon Dec 12, 2016 9:11 pm
Very interesting, my problem is my S2 has aftermarket jap bars on so cables are a novel one.
Just a few months ago I noticed a fraying cable, so fitted my spare. :roll:
I was thinking about get some bespoke ones made up . This would eliminate many issues .
Let us know Johnr ......or we could use mine as a template if yours aren't ready....wink wink! ;)
spondonchris
Has thanked: 18 times
Been thanked: 18 times
Post by spondonchris » Mon Dec 12, 2016 9:52 pm
cheap as chips if it works! Have been thinking of trying a full hydraulic clutch conversion but as usual, not got round to it. I believe using a GSXR or similar set up with some sort of extra long rod set up can work. Cant remember where I saw that now. Think it was on OSS. Will wait to hear how your way goes ;)
KOC397
Nigelkat
Has thanked: 1 time
Post by Nigelkat » Mon Dec 12, 2016 10:38 pm
Look like a very neat solution. My only concern would be the quality of the components. but hey for £5.85 worth a go.
Post by johnr » Tue Dec 13, 2016 10:28 pm
the idea of using a gsxr setup would depend on drilling a gear shaft to take the actuation rod, i read the oss thread and its interesting, i will have a look to see if i have any ready drilled capped off shafts. ive also got a dilema round a lockup clutch i just aquired, it requires an extended actuator from the cover to the inner basket to lift the clutch. but if i go for the gsxr idea, this part becomes unnecesary as well as. decisions decisions...
Post by johnr » Tue Dec 13, 2016 10:29 pm
Nigelkat wrote:Look like a very neat solution. My only concern would be the quality of the components. but hey for £5.85 worth a go.
my thought exactly, just need to get the right size master cylinder for it.
Post by fossie » Tue Dec 13, 2016 10:46 pm
Forgive me here, but surely the rod can only move out then return, isn't that opposite to the Kats operation unless the arm is reversed. :?: :roll:
Post by johnr » Wed Dec 14, 2016 12:36 am
the rod puls like the cable and is screwed into the threaded mounting on the top crankcase. operating the lever pulls it, not pushes.
