KatanaBob
- Been thanked: 4 times
Post
by KatanaBob » Sat Nov 19, 2016 4:06 pm
Hi all,
Im looking for a gasket set for my 750 pop-ups carbs. They are Mikuni BS32SS
Does any know if the 1984 1100S has the same carbs? I found a gasket set for this model but cant find which model carb it actually is?!
Thanks in advance
Sent from my SM-G900F using Tapatalk
KatanaBob
Post
by KatanaBob » Sat Nov 19, 2016 6:51 pm
Thanks Steve! I am more wondering if the float bowl gasket and float needle/seat are the same. Wemoto have the individual sets but are a little pricy.
- Has thanked: 128 times
- Been thanked: 269 times
Post
by Kryten » Sat Nov 19, 2016 11:02 pm
BS32 and BS34 carbs will be basically the same with the difference in the bore and the slides and butterfly valves. The float bowl gaskets and the O rings and the float needle valves will be the same. NRP do the Keyster kits. I think if you are club member you may get a discount
Uncle_Bob was looking into identifying Nitron O rings for the 1100 carbs as he did for the 400.
- Been thanked: 343 times
Post
by johnr » Sun Nov 20, 2016 4:41 pm
i think the bodies are basically the same, aside from the jets and the way the are machined. i think the gaskets diaphragms etc will be the same.
KatanaBob
Post
by KatanaBob » Sun Nov 20, 2016 7:50 pm
Great! Thanks guys!!
- Has thanked: 187 times
- Been thanked: 738 times
Post
by fossie » Wed Nov 23, 2016 11:21 pm
The carb gasket set is the same as GSX 750 ES/d/e/f/g.1983-89.
KatanaBob
Post
by KatanaBob » Fri Nov 25, 2016 6:52 am
Thanks!
