JIS Screws - Well I never knew that...!
Post by Uncle Bob » Wed May 13, 2015 9:58 am
While researching the carb stripdown on the 400 I came across a few articles about Japanese bikes using JIS (Japanese Industry Standard) screws and not Philips, though they look similar - 30 years of working on Jap bikes and this is the first I have ever heard of this!
http://www.xrv.org.uk/forums/africa-twi ... -bike.html
or Google other useful sites... I checked some the screws I replaced on the carbs and sure enough they did have the dot on them.
Perhaps that explains all the rounded heads over the years (apart from the screws being made of chesse of course) with the Philips screwdrivers "camming out" of the slots and chewing them up. I have gone and bought (at great expense!) a P1, P2 and P3 screwdriver to see if indeed they work better.
http://www.ebay.co.uk/itm/171753460588
Was I the last to know?
Re: JIS Screws - Well I never knew that...!
Post by fossie » Wed May 13, 2015 1:02 pm
Have to say ....news to me too, never a question I ever asked. Just assumed. Like most naff screws ...made of cheese was the phrase if I remember .
But as known assume. Makes an ass of U and me !
Post by callyboy » Wed May 13, 2015 1:57 pm
Well well. that explains a lot. I know that you always had to get a very tight fit if you used a Philips screwdriver or it would probably chew. I always replace the bastards with allen heads after I have smashed the feck out of em :)
Soichiro
Post by Soichiro » Fri Nov 06, 2015 9:31 pm
A Phillips No 2 screwdriver with the tip ground off slightly does JIS screws perfectly. I wish I knew that years ago too
GS650G - Biggest pile of crap on the planet
400FOUR (F2 in Candy Antares Red)
jasonexup
Post by jasonexup » Sat Dec 12, 2015 6:46 am
I've had this set of screwdrivers for quite a while....well worth the investment. They have little ridges on the ends for extra grip on the screw..
http://www.ebay.co.uk/itm/Vessel-9003-S ... Sw~gRV5ySZ" onclick="window.open(this.href);return false;
750 S2 (temporarily has 1100 motor)
750S3 pop-up in many pieces
GPz1100a1 with Triumph Suspension Grafted In, running awaiting modified sprocket
