Bleedin bleedin clutch
Posted: Fri Apr 10, 2015 5:47 pm
I'm just posting this because it's always entertaining to read of others misfortunes.
Before I took the popup off the road the hydraulic clutch had started dragging to the point where it wouldn't disengage at all and the lever was back to the bar with no pressure...
Put a new seal kit in the MC.
Slave cylinder and seal looked good, so cleaned and reassembled.
Everything back together.
DOT 4 fluid, bleed, bleed, bleed.
Nothing.
Exactly as before. It feels like the line is full of air - no pressure at the lever.
No fluid leaking anywhere.
Used a mityvac vacuum bleeding gadget.
Nothing.
Got a big syringe and reverse bled it from the slave cylinder.
Nothing.
Took off the clutch cover and the centre is moving, but only about a millimetre.
I hate this clutch and I especially hate whoever dreamt up brake fluid that spreads everywhere and strips paint.
Should have used DOT 5.
So I've just ordered a new seal for the slave cylinder. What else can it be???
Nothing.
Nothing.
Nothing.
