Idle adjuster
Kat_mad_x2
Idle adjuster
Post by Kat_mad_x2 » Tue Feb 10, 2015 10:44 am
Feck feck and feck....
Was out starting the bike got her running nicely and came in for a cuppa, as you do I nodded off for an hour and came out to my brothers 9year old twisting the Idle adjuster.... Bike now won't start arrgh he swears he didn't tough anything else...
Any ideas people
Bike spins over but won't catch?
Gsx 1100s 1983
Gsx 400s 1992
Re: Idle adjuster
Post by pookie » Tue Feb 10, 2015 3:55 pm
Try turning the idle adjuster all the way in (clockwise i think) then spin the motor over while backing it out, if it has been messed about with it should fire up at some point, i know the trouble kids can cause to bikes, i was cleaning my kat when i got distracted by my nephew wanting to sit on it, ten minutes later i went to start it and nothing happened, found out after much f'ing and blinding that the little basket had put it into first gear when i wasn't looking, that was the day i found out that there was a safety cut out switch on the starter!
Re: Idle adjuster
Post by fossie » Tue Feb 10, 2015 9:17 pm
Turning the idle adjuster all the way each way won't stop it starting.
A 9 year old in the shit will always deny.
A kid will always twist the throttle loads and loads. Flooded........
Leave it a while.
Does it turn over?
Re: Idle adjuster
Post by bobster » Tue Feb 10, 2015 9:55 pm
HAS IT RUN OUT OF FUEL............... ;-)
Kat_mad_x2
Re: Idle adjuster
Post by Kat_mad_x2 » Wed Feb 11, 2015 7:42 pm
Yeh she is definitely turning over and has fuel she toys to start (only very low revs for few seconds)and quits
Gsx 1100s 1983
Gsx 400s 1992
Re: Idle adjuster
Post by callyboy » Wed Feb 11, 2015 7:43 pm
Choke?
Kat_mad_x2
Re: Idle adjuster
Post by Kat_mad_x2 » Wed Feb 11, 2015 10:30 pm
Have choke on
Gsx 1100s 1983
Gsx 400s 1992
Re: Idle adjuster
Post by johnr » Wed Feb 11, 2015 10:34 pm
has he turned the fuel to prime? unwind the idle adjuster, till its loose, then wind it in till you feel resistance as it touches the throttle stop, then wind it in a couple of turns more, try staring it then, but be prepared to shut it off if the revs fly up.
Re: Idle adjuster
Post by bobster » Thu Feb 12, 2015 2:01 am
OK, If it has fuel...has it gone onto reserve?
Kat_mad_x2
Re: Idle adjuster
Post by Kat_mad_x2 » Thu Feb 12, 2015 2:24 pm
Nope definitely hasn't :( not flooded either left her for couple of days and still not firing :(
Getting a spark smells like she is getting fuel I'm lost
Gsx 1100s 1983
Gsx 400s 1992
