Popup front brake caliper id puzzle
prothed
Been thanked: 5 times
Post by prothed » Thu Jan 08, 2015 6:11 pm
During the winter tidy up I thought I'd give the forks the once over - no problem until I get to the calipers...
A couple of the rubber boots that cover the pins need replacing, so check the Fowlers on-line parts fiche for the 750SE 1984 and - those aren't the right calipers.
Mine are single piston and the parts fiche shows twin piston.
I looked back at previous years - single piston but the design looks different.
Pic of mine attached - Can anyone id them?
Re: Popup front brake caliper id puzzle
Post by callyboy » Thu Jan 08, 2015 7:27 pm
Mine:
that one looks like the one on my 550. Think its on a few different models tbh.
Best brakes i have had tbh :)
Post by fossie » Thu Jan 08, 2015 9:04 pm
Those brakes are from an Es or earlier Kat which means we need a photo of the forks , you may have the wrong forks .
TBHI have to agree with callyboy, not bad brakes and so much easier to deal with than the SEones that just fit in the rim .
prothed
Post by prothed » Fri Jan 09, 2015 8:24 am
Ah, they do look like the ones in Callyboys photo.
Which model/year is that?
Here are my forks (poor photo sorry) - they look ok for the year...
Post by fossie » Fri Jan 09, 2015 9:37 pm
Well there you go pop up (s3). And s1/2 brakes. Just refurb them and ride it , you didn't know before.
prothed
Re: Popup front brake caliper id puzzle - SOLVED
Post by prothed » Sun Jan 11, 2015 5:07 pm
Bingo. GS550MX/MZ it is.
Thank you both very much for your help.
Post by fossie » Sun Jan 11, 2015 7:27 pm
Not so fast callyboy , the brakes may look the same BUT the pads are different sizes, so don't be jumping to conclusions , best get the EBC brake pad book which has actual size outline of every pad and models it fits , this will give you the precise model of Suzuki they came from.
Post by callyboy » Sun Jan 11, 2015 7:35 pm
Who???
prothed
Post by prothed » Mon Jan 12, 2015 9:57 am
Oh... Thought this was sorted. The 550 pads look the right size and shape but (fossie) if you know of any other models that are similar but different then I will double check before ordering. Thanks.
Post by Kryten » Mon Jan 12, 2015 11:14 am
Huh?
Just had a scan through WEMOTO's site and they list EBC pads for the GS550mx, GSX750 S1 and the GSX1100 SZ as being FA065 71.6 x 45.2 x 11.5mm
Always thought that the pads were all the same for those type of caliper
http://www.wemoto.com/bikes/suzuki/gs_5 ... d_gg_type/" onclick="window.open(this.href);return false;
http://www.wemoto.com/bikes/suzuki/gsx_ ... d_gg_type/" onclick="window.open(this.href);return false;
And Robinsons list the pads for the SZ as fa65
item 4
http://www.robinsonsfoundry.co.uk/conte ... aliper.htm" onclick="window.open(this.href);return false;
