Page 1 of 2
Fork Springs - Which way up
Posted: Fri Dec 19, 2014 5:00 pm
by Uncle Bob
Do the fork springs have the tighter coils at the top or the bottom when reassembling?
I forgot it's been so long!
Re: Fork Springs - Which way up
Posted: Fri Dec 19, 2014 6:25 pm
by Uncle Bob
Pretty sure they were tight wound at the top.
Just Googled to see what the web says and the web says:
- Definately tight at top
- Definately tight at the bottom
- It definately doesn't matter!
:D Don't you just love Googling things.
Posted: Sat Dec 20, 2014 9:08 am
by Kryten
One of the Pride articles I did was swapping out the springs for progressive rate ones. According to the Hagon instructions: Tight coils to the top
Posted: Sun Dec 21, 2014 7:56 pm
by Uncle Bob
Cheers Kryten, that is the way I will do it.
Posted: Mon Dec 22, 2014 7:07 pm
by jerry
Just had a set of Hagon 'road' shocks made slightly longer eye to Clevis for my winter updates. Made up by Dave at Hagon and delivered today. Tighter springs at bottom ;). So it does seem with all the different advise we seem to be getting...it really doesn't matter.
Posted: Mon Dec 22, 2014 8:19 pm
by Kryten
Rear shocks may well be different to the front forks
Posted: Mon Dec 29, 2014 5:40 pm
by prothed
In the FSM (for the 750 though) it says tight coils to the top...
Posted: Tue Dec 30, 2014 5:24 pm
by lomsavage
seem to remember (in dim and distant past) fitting progressive fork springs on the gs, they were tight at the top
If my logic serves me right that means smaller bumps are evened out by the wider bits and as they compress harder bumps are resisted by the tighter coils giving an ultimately smoother more even suspension action
Posted: Mon Jan 05, 2015 9:35 am
by Uncle Bob
Are the 1100 Progressive as standard? I just have what mine came with which is tighter at one end.
I put them in tight at top, for reference.
Posted: Mon Jan 05, 2015 11:47 am
by Nicky Dodds
Same as mine rob.
