Cold compresion testing? 650z
craven wine
Post by craven wine » Tue Nov 11, 2014 7:51 pm
I can only assume compression test figures of 90-90-60-90 psi on the four pots is not good news and points to a problem on pot four. What would the normal 'cold' figures be. Apologies if this is fixtures on another thread!
Re: Cold compresion testing? 650z
Post by callyboy » Tue Nov 11, 2014 8:28 pm
Not very high :( You mean 3 not 4 right ?
Were the carbs on? I only recently found out that your supposed to have the throttle open :oops: :oops:
craven wine
Post by craven wine » Wed Nov 12, 2014 8:27 am
callyboy wrote:Not very high :( You mean 3 not 4 right ?
good point! the silver lining being any residual petrol is sucked out of the carbs..and yes it was pot 3 that was deflating.. I don't expect any great difference with an open throttle other than the joys of my first proper rebuild! :o
Post by sparki » Wed Nov 12, 2014 1:31 pm
And plugs out...
Post by bobster » Wed Nov 12, 2014 6:34 pm
Then try it again with a squirt of engine oil and see what the difference is between dry and wet....
Have you checked the valve clearance on all the cylinders. How many miles has the oild girl done? You need to have the throttle fully open to do a comp test as Pete says!
Post by johnr » Thu Nov 13, 2014 3:39 pm
have you first checked the valve clearances to make sure they arent being held open.
Post by bobster » Thu Nov 13, 2014 4:55 pm
I guess you never read my post then John.................. ;-)
Has thanked: 4 times
Been thanked: 61 times
Post by stockcar » Thu Nov 13, 2014 7:09 pm
regardless of exact throttle opening used you need to ensure you repeat the method used for each cylinder for comparable results
Post by johnr » Thu Nov 13, 2014 11:40 pm
tiny screen on the phone i was reading it on. i didnnt see that bobster.
Been thanked: 198 times
Post by Pedda » Fri Nov 14, 2014 12:37 am
bobster wrote:I guess you never read my post then John.................. ;-)
There was no answer yet... :mrgreen:
