fitting carbs
Posted: Wed May 14, 2014 3:30 pm
by BigLT
Anyone have any top tips for fitting carbs onto the bike?
I would try brute force, but that doesn't always work out too well for me.
Re: fitting carbs
Posted: Wed May 14, 2014 7:19 pm
I found a ratchet strap helps if on your own. Slowly tighten it and make adjustments on the carb rubbers as they go in (or not!!!).
Also do it on a warm day when the rubbers have softened in the sun :)
Re: fitting carbs
Posted: Wed May 14, 2014 9:31 pm
by BigLT
I've got a heat gun and ratchet straps.... I'll give it a go.
thanks for the help.
Liam
Re: fitting carbs
Posted: Sat May 17, 2014 4:00 pm
by BigLT
Heated up the rubbers: carbs went on no probs. thank you
