650 kat bad running
pete650kat
Re: 650 kat bad running
got the ht leads right? left coil as youre sitting on her is 1 and 4 and right coil is 2 and 3. gets me every time? have you checked wiring to coils from lom is correct also and the earth that sits by the horn can be a bit dicky. other than that sorry cant help but fossie will probably tell you by using the power of the force?
pete650kat
no worries, its not so much the horn but on my two 650's there was a large ring terminal that goes under the bracket that the horn mounts to above no 1 cylinder on the frame rail. best of luck anyway
- Has thanked: 187 times
- Been thanked: 738 times
The earth to under the horn mounting bolt is important all sorts of mysterious electrical goings on with out it.
However your issue is a blocked emulsion tube . Also check vacuum pipe from inlet end. Or indeed is it connected ? Modern fuel cannot be left. For a year with out gumming up , because the fuel is fed in between 2 and 3 carbs these get blocked .
- Been thanked: 343 times
also worth remembering that if its full of year old fuel its gonna run like a nail! modern petrol can go off in a few short weeks, so you might just have a load of crap fuel.
