Kat 1100 sprocket spacer
tomtom
Post by tomtom » Mon Mar 03, 2014 11:55 pm
Can someone tell me please behind the front sprocket on the 1100 Kat is a sleeve that partially fits into the sprocket seal. How long should this be and should there be any other washers or spacers fitted before the sprocket goes on. Many thanks.
Has thanked: 55 times
Been thanked: 210 times
Re: Kat 1100 sprocket spacer
Post by Pedda » Tue Mar 04, 2014 4:21 pm
18,5 mm long, no additional washer or spacer if you are using stock rear end.
Post by bobster » Tue Mar 04, 2014 7:07 pm
Isnt there a tiny O ring that goes in first..................?
Post by Kryten » Wed Mar 05, 2014 11:01 am
bobster wrote:Isnt there a tiny O ring that goes in first..................?
There is I believe, but I did not fit one on my 750, as I could not see a groove for it to locate on. Does it just compress between the spacer and the bearing?
I have not locked up the sprocket nut yet, just another of the little jobs to do :roll:
Post by bobster » Wed Mar 05, 2014 6:49 pm
Yep it just squashes..............a smear of loktite or silicon sealant will prob do the same job tho!
tomtom
Post by tomtom » Wed Mar 05, 2014 10:40 pm
Thanks for the info guys.
