310mm discs for katana?
Posted: Fri Nov 01, 2013 8:58 pm
by BigLT
Is there a 310mm disc that fits katana wheels?
Closest I can find is cbr1100xx, but the inner diameter is 6mm bigger -
Liam
Re: 310mm discs for katana?
Posted: Sat Nov 02, 2013 10:40 am
by Katgeezer
Gixxer 310mm discs fit an EFE wheel but not sure about older Kat wheel. You need to space the calipers as well however.
Posted: Sat Nov 02, 2013 12:33 pm
by BigLT
Thanks, but need approx 56mm inner diameter and 6 bolts.
Liam.
Posted: Sat Nov 02, 2013 10:47 pm
well, the fe kats all had bigger disks, and the 400s came with huge disks although theyre on 18 inch rims with the same spoke pattern as all the gs/gsx range.
