pop up choke
pop up choke
Post by callyboy » Sun Jun 09, 2013 12:43 pm
Does the knob stay in the on position by itself ? or will it just spring back which is what mine is doing at the moment?
thanks
Re: pop up choke
Post by Katgeezer » Sun Jun 09, 2013 1:31 pm
There's a wavy washer that goes under the knob and provides a resistance to it springing back. They usually go missing. I don't think I've got a single one!!! Clothes peg on the sliding bit at the carbs while you put your gloves on then just ride.
You can get the washers still. A large fibre or rubber washer would probably work too if you can find one big enough. B&Q maybe?
Re: pop up choke
Post by callyboy » Sun Jun 09, 2013 5:08 pm
Cheers Chris, will have a look in my fibre/rubber washer stash ;)
Re: pop up choke
Post by Pop-Kat » Sun Jun 09, 2013 5:36 pm
I saw the choke fixings on ebay the other day, not a lot of dosh, think it was listed under "Suzuki katana"
Re: pop up choke
Post by Pop-Kat » Sun Jun 09, 2013 5:42 pm
found it
http://www.ebay.co.uk/itm/Genuine-Suzuk ... 3cd261b92d" onclick="window.open(this.href);return false;
Re: pop up choke
Post by callyboy » Sun Jun 09, 2013 7:41 pm
:) Cheers Mal. I had that on my watch list believe it or not. Wasnt sure whether to get it or not tbh. Mine seems to work ok apart from not staying on. Will try a fibre washer underneath it like Chris said.
Re: pop up choke
Post by fossie » Sun Jun 09, 2013 9:42 pm
Any thin washer will do just make sure it fits well around the centre of the choke knob and then bend it a bit.
It sits between the panel and knob.
Re: pop up choke
Post by callyboy » Mon Jun 10, 2013 12:15 pm
Seems to work ok now. Put a big rubber washer between the knob and the panel and i suppose it offers just enough friction to hold the knob when its on :o :o
Thanks for the info
Katman
Re: pop up choke
Post by Katman » Mon Jun 10, 2013 3:16 pm
Complete choke knob set here http://page16.auctions.yahoo.co.jp/jp/auction/u48963735" onclick="window.open(this.href);return false;
cheap as chips too
Re: pop up choke
Post by sparki » Mon Jun 10, 2013 3:49 pm
excuse my ignorance.... but how do you search on the yahoo site? sounds stupid i grant you but cannot work it out? would love to have a browse around and see whats what on it
