Suzuki 650 GZ Katana Footrest
Posted: Sun May 12, 2013 12:23 pm
by craik
I was trying to replace the LH-front footrest on my bike, which has seen better days, with a new one.
The footrest seems attached by a single bolt held in place by a split pin, and I thought it would be a simple job of removing the split pin and pushing out the bolt.
However, even applying oil overnight to free up the bolt and using a hammer, it seems stuck.
Any ideas on how to best remove the bolt (and peg)?
Thanks in advance for any advice.
Re: Suzuki 650 GZ Katana Footrest
Posted: Sun May 12, 2013 12:28 pm
I got stuck on that bit as well :( gave up in the end ;)
Posted: Mon May 13, 2013 8:27 am
by craik
Darn, was hoping to save some money by doing it myself rather than taking it into a bike shop.
Anyone? Fossie? :) :?:
Posted: Mon May 13, 2013 8:51 am
by bobster
You'll prob find the cotter pin has seized or worn and has 2 grooves in the pin not allowing the pin to be reomoved. Try turning the pin 180 degrees and give it a whack with a pin punch and hammer!
Posted: Wed May 15, 2013 7:34 pm
by craik
I can get the split pin out easily enough, but not the bolt it secures!
PS I'm getting confused. I thought a spilt pin is the same as a cotter pin, it's just the latter is the American name for it...
Posted: Wed May 15, 2013 10:48 pm
A split pin is just that. a pin that splits.
A cotter pin is a threadless bolt that has one side usually chamfered or notched , it is a tight fit thus requiring no nut.
The pedals on a bicycle are held on to the crank with such an item.
