750 kat fork seals
kiwi k
Re: 750 kat fork seals
Post by kiwi k » Thu May 09, 2013 5:25 pm
Very easy no need to strip forks either, just remove said fork/s and remove dust cover/s, then pop out spring retainer and drive 2/3 small long self tapping screws into seal and gently pull it up with pliers or grips out of fork tube, if in doubt tape card around tanchions to protect.
kiwi k
Post by kiwi k » Thu May 09, 2013 7:11 pm
plenty on ebay, just make sure you get right year and model ;)
What i also should of said :roll: is are the stanchions free from rust pits and scratches on the area of seal travel :?: , because if not then new seals won't last long :!:
kiwi k
Post by kiwi k » Thu May 09, 2013 8:12 pm
As long as its a 1982 Suzuki GXS750S Katana with standard forks should be these
http://www.ebay.co.uk/itm/Pyramid-Parts ... 374wt_1051" onclick="window.open(this.href);return false;
or seals and dust caps
http://www.ebay.co.uk/itm/Pyramid-Parts ... 459wt_1051" onclick="window.open(this.href);return false;
but to double check measure to see if stanchions are 35mm
Post by sparki » Thu May 09, 2013 8:41 pm
i thought the 750 1000 and 1100 were all the same.... my forks, 750, are 37mm
kiwi k
Post by kiwi k » Thu May 09, 2013 9:16 pm
Steve they are but i think he got confused over the 750 options
Post by bobster » Fri May 10, 2013 9:18 am
Fit genuine Suzuki seals or you'll be fitting another set in no time at all!
