Cam chain 650
Posted: Mon Dec 10, 2012 10:46 pm
Finally got a bit of time yesterday to do a bit on the German 650.
After I fitted the cleaned carbs a few months ago, it started and ran but cyl 3 and 4 didn't, get as hot as the other 2, so I was going to balance the carbs, but first do the shims.
On taking cam cover off, I noticed the front cam notch [at end) was not as level as the rear when they are set to open valves. However more important is the cam chain was the correct tension but when the crank nut was turned the chain was slack , then tight,then slack,tight ,etc.."". Any ideas?
To be honest when it was running there was a buzzing noise from that area, but it went at revs, but came back.
