Page 1 of 2
Whats this?
Posted: Sun Oct 21, 2012 7:50 am
Round black thing. Something to do with rear shock adjustment ?
Re: Whats this?
Posted: Sun Oct 21, 2012 8:52 am
by sparki
Preload adjuster... Or rebound adjuster...
Re: Whats this?
Posted: Sun Oct 21, 2012 9:46 am
by Pop-Kat
It's the rear shock preload adjuster, follow the cable to the shock and you'll probably find it's split where it takes a tight turn. If not you have the rarest popup out there, the one where the preload still works
Re: Whats this?
Posted: Sun Oct 21, 2012 10:56 am
by Katgeezer
If you want to take it off be careful they can be tricky to remove.
Re: Whats this?
Posted: Sun Oct 21, 2012 12:17 pm
cant turn the thing. so assume its buggered. will have a look when its been oily ragged
Re: Whats this?
Posted: Sun Oct 21, 2012 3:21 pm
by Katgeezer
Probably just needs the wonders of WD or similar.
Re: Whats this?
Posted: Sun Oct 21, 2012 3:22 pm
Katgeezer wrote:Probably just needs the wonders of WD or similar.
Will give it a squirt then
Re: Whats this?
Posted: Tue Oct 23, 2012 7:35 am
The adjuster is actually a cable so gets full of grime in the kink as arnica said. You can undo the cable at shock end and lube it.
If you lok at the back of adjuster there is a sight glass with a ball bearing it it to show the setting , move it to 5 and forget it.
Re: Whats this?
Posted: Tue Oct 23, 2012 3:11 pm
by outrage
Believe it or not but mine is fully functional. Winds in n out no problem and you can feel a difference between hard n soft.
Re: Whats this?
Posted: Tue Oct 23, 2012 3:32 pm
by Smand
outrage wrote:Believe it or not but mine is fully functional. Winds in n out no problem and you can feel a difference between hard n soft.
Lucky Girl!(cough,
partner
