headstock bearing collar
bagman
Post by bagman » Sun Sep 23, 2012 2:34 pm
For some reason I can't get the top collar back into the frame! I',ve had it in the freezer over night, don't want to add heat as the frame has been repainted....any suggestions?
ta
Re: headstock bearing collar
Post by callyboy » Sun Sep 23, 2012 2:38 pm
Has the frame been painted where the collar goes in?
Been thanked: 198 times
Post by Pedda » Sun Sep 23, 2012 3:00 pm
It's a good idea to grind the outer race on the outside to make it almost "fall" home into the headstock. Then take some locktite or similar and fix it, with the whole yoke assy tightened in place to make sure the bearing race is seated correctly.
This way you avoid the bearing race getting oval because of the facturywise mostly non-circular headstock.
There's a German bearing specialist called Emil Schwarz, who cures running gear problems on motorbikes by (not only) this method.
http://www.emilschwarz.de/dev/index.php?id=100" onclick="window.open(this.href);return false;
Don't do that grinding by hand though - it has to be done precisely.
bagman
Post by bagman » Sun Sep 23, 2012 3:18 pm
pete...no I cleaneed all the paint from the inside already...it's now shiney ;)
peda...thanks for the info :)
what i don't understand is the collar just fell out in the first place!
