popup engine swap
peterrr
popup engine swap
Post by peterrr » Tue Sep 11, 2012 5:55 pm
I was wondering if any of you guys ever changed the engine from a popup kat with a GSXR750 or GSX750F (oil cooled offcourse)
I want to change engine next year
thanks
GSX1100SZ, GSX750SF, GSXR1100, GSX750SE popup special
Re: popup engine swap
Post by bobster » Tue Sep 11, 2012 6:32 pm
I think Mal ( Arnica) has fitted an 1100EF motor to a Popup............
Dont think it was straight forward though!
As with all things, anything will fit if you try hard enough............It just depends on how much cutting, welding and modding you want to do!
Post by callyboy » Tue Sep 11, 2012 6:59 pm
Yeah, think he had to stretch the frame to get it in.
Post by Pop-Kat » Tue Sep 11, 2012 8:19 pm
The GSXR or F engine should go in pretty easy, the rear mounts will probably line up ok, the standard popup engine is very similar to the gsxr in size. you might ? get a bit of trouble with tank to cam cover clearance and clearance to the petrol tap.. Will be muuuch easier than putting an 1100ef engine in ;)
Post by sparki » Wed Sep 12, 2012 8:35 am
shouldn't be that tough.... pretty much the same size those newer oiled cooled motors...
peterrr
Post by peterrr » Wed Sep 12, 2012 11:10 am
Thing is, I don't want to stretch the frame to get an 1100 in it, The engine from a GSXR1100 is also a little too high so thats why I want a GSXR750.
Think I'll start looking for a good engine and give it a try :)
Post by sparki » Wed Sep 12, 2012 12:54 pm
oil cooled 750s should be fine tbh.... have a measure first but cannot see it being an issue.
try on oldskoolsuzuki as they all seem to hate the 750 motors and bung 11s in. i'd try to get one complete with starter, alternator, cooler, pipes, ignition etc to save ££
all the small bits add up fast
peterrr
Post by peterrr » Wed Sep 12, 2012 2:25 pm
sparki wrote:oil cooled 750s should be fine tbh.... have a measure first but cannot see it being an issue.
Try yo get as many parts in one sale is a good tip.
And I will take some measurements first. I think a 750R motor will look good in a popup.
8-)
