clutch slip
dave309
clutch slip
Post by dave309 » Mon Aug 13, 2012 7:51 am
hi again got me carbs sorted now next problem is clutch slip and lots of it so whats the best plates to use and has anyone got any tips for increasing its performance
allready got all 6 heavy duty springs fitted allso heavy duty backplate/springs/rivets billet basket and ef inner hub any ideas
Re: clutch slip
Post by sparki » Mon Aug 13, 2012 8:57 am
hard to beat oem plates imo.... not that expensive and ya know what you're getting.
Re: clutch slip
Post by Katgeezer » Mon Aug 13, 2012 10:25 am
OEM plates are best.
Barnett are quite good I believe and generally views are mixed (at best) on EBC.
What oil you using? As has been said on here many times synthetic oil will make clutches slip in some (especially our old lumps) engines.
Re: clutch slip
Post by sparki » Mon Aug 13, 2012 11:00 am
aldi/tesco/own brand mineral oil is cheapest and has minimal additives compared to the others. the more basic the better for these engines imo
Re: clutch slip
Post by johnr » Tue Aug 14, 2012 3:59 pm
barnett kevlar are very good, but beware, they are very grabby, you dont get much chance to slip them, so if you do any rding in traffic, then theyre a bit of a non starter. for normal use and even use on the strip, its pretty hard to beat standard suzuki plates. even he guys with some big bhp bikes run stock plates in their fancy clutches.
Re: clutch slip
Post by johnr » Tue Aug 14, 2012 4:00 pm
and a good way to increase your performance might be to,,,,,
,,,,,,,, fix your slipping clutch!!!!
