popup flywheel removal
Been thanked: 715 times
Post by fossie » Tue Feb 01, 2011 1:31 am
Now forgive me but I thought I'd asked this before but there has been no replies which I found unusual, now I can't find the thread so either I wrote it somewhere else or I dreamt it!!!!! :shock:
Anyway forgive the duplication if it is so . :lol:
I need to extract the flywheel (rotor)from the crank, It isn't very impressed and is as stubborn as my daughter on a mule! :twisted:
What I need is a flywheel puller for a 750 se/es However I suspect it may be common.
We need to show it restistance is futile. :P
Has anyone got one I may borrow.
dave309
Re: popup flywheel removal
Post by dave309 » Tue Feb 01, 2011 5:15 am
is it the same as the 1100 puller
Post by fossie » Tue Feb 01, 2011 10:22 pm
Not 100% sure but can't see why it wouldn't work.
dave309
Post by dave309 » Wed Feb 02, 2011 6:43 pm
got one can post if you want
Post by fossie » Wed Feb 02, 2011 9:46 pm
That,ll get great Dave, I'd come over to collect it but the shift system, negates that at the mo.
Let me know how much postsge.
Post by fossie » Wed Feb 09, 2011 12:34 am
Dave309 kindly came ver to mine on Sunday with 1100 puller.BUT it doesn't fit sadly, the thread on the 1100 is 34 mm and we need 30mm,
Any ideas?
Post by bobster » Wed Feb 09, 2011 1:00 am
I will see if I can get one made at w0rk.........what is the pitch of the thread? is it 3mm?
Does it just need to screw on to the flywheel and have a H/Tensile bolt threaded to screw against the end of the crank.
And with a couple of flats machined in the body of the puller to hold with a big spanner.
Do you have a pt nos for the correct puller as I may be able to borrow one to copy!
Post by fossie » Wed Feb 09, 2011 1:08 am
Bobster my man your desciption in both correct and eliquent.
Iwill seee if the part number is in manual tomorrow. Ta!
JACKJABBA
Post by JACKJABBA » Wed Feb 09, 2011 3:35 pm
Is it like this.
http://cgi.ebay.co.uk/Flywheel-Puller-M ... 144wt_1135
Maybe we could have one in the clubs tool section?
GSX1100SZ
RD500LC
RD250LC
VF1000R
KE 125 1976
KOCUK 316
Post by sparki » Wed Feb 09, 2011 4:20 pm
think the thread is on the wrong side of the doo-hickey in that one
