KPH speedo
KPH speedo
Post by callyboy » Tue May 29, 2012 10:35 am
Whats the mot requirement for a bikes speedometer ? does it have to read mph or can you get away with some stickers stuck on it for mph ?
Ta
Re: KPH speedo
Post by Katgeezer » Tue May 29, 2012 11:02 am
Just googled it Pete (come on you could do that too ;) :lol: ) and for CARS if you're running British plates etc then you have to have MPH readings. Soooo, assuming it's the same for bikes then stickers for 30,40,50 and 70MPH should be sufficient those being the common speed limits.
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Re: KPH speedo
Post by lomsavage » Tue May 29, 2012 11:23 am
When perky was on the road it had kph clocks, no stickers and had no probs with MOT
Hello from H
Re: KPH speedo
Post by callyboy » Tue May 29, 2012 3:27 pm
Thanks guys. Just double checked and speedo is not checked at a MOT test - but is is illegal not to have one. Not sure about the mph thing. But stuck some stickers on it just in case i ever ride it out the garage!!! Pre-emptive strike.
Re: KPH speedo
Post by johnr » Tue May 29, 2012 4:37 pm
as you say, speedo isnt mot-able, so it matters not, you need a means of gauging speed, to compley with c+u regs, so i dont see why a kph one wont do it, just put stickers on to corespond with 30-40-50-60-70mph!
Re: KPH speedo
Post by callyboy » Tue May 29, 2012 5:38 pm
Cheers. should have done something when i had the clocks off.
Re: KPH speedo
Post by fossie » Thu May 31, 2012 12:28 am
There is no legal requirement, in fact most of my bikes are mph less , I just see 50 as 30, 60 as 40 , 80 as 50, 100 as 60, and any thing over as time for mirror checking!
