Page 1 of 2
Generator cover
Posted: Tue May 22, 2012 6:49 pm
by AndySwad
May be a stupid question but will the generator crankcase cover simply pull off after the case screws are removed, mine seems loose stuck at the bottom, not too good at gentle so don't want to damage anything by prising off
Re: Generator cover
Posted: Tue May 22, 2012 7:26 pm
by FBJ
Hi Andy. Take the starter motor out and make sure the alternate wire is free. Give the casing a couple of taps with a rubber mallet. As u pull it free make sure u feed the wire through. They are sometimes tight
Re: Generator cover
Posted: Tue May 22, 2012 7:50 pm
it will just be stuck on one of the dowels, they can seize in situ being steel dowels in an ally casing. just tap it with a malet or rubber hammer
Re: Generator cover
Posted: Wed May 23, 2012 10:06 am
by sparki
and obviously there's a magnet involved.... but 2nd john's comment re the dowel being corroded
Re: Generator cover
Posted: Tue May 29, 2012 8:52 pm
by AndySwad
Yes it was corroded bush
Re: Generator cover
Posted: Tue May 29, 2012 8:53 pm
by AndySwad
mmm can you get cream for that?
Re: Generator cover
Posted: Tue May 29, 2012 9:41 pm
by Pedda
Copper based lube.
Re: Generator cover
Posted: Thu May 31, 2012 3:19 pm
by fetishkat
My Doc gave me a cream!!! :lol:
Re: Generator cover
Posted: Thu May 31, 2012 4:27 pm
pop a bit of coppaslip or acf50 grease on it when you reassemble, and use a genuine gasket, pattern ones dont cut it there!
Re: Generator cover
Posted: Thu May 31, 2012 6:28 pm
by bobster
I always lightly grease casing gaskets before fitting, as they can sometimes be used again if not broken. And it make removing the remnants from the cases a lot easier too!
