Oil & Filter Change
BanditAl
Been thanked: 6 times
Oil & Filter Change
Post by BanditAl » Sat May 12, 2012 5:57 pm
Hi,
How much oil for an oil and filter change on the 650 Kat.
Alan
KOC16
FBJ
Has thanked: 5 times
Been thanked: 31 times
Re: Oil & Filter Change
Post by FBJ » Sat May 12, 2012 6:26 pm
It will say somewhere near the filler. Then maybe another 100cc for filter ;-)
Katman
Post by Katman » Sun May 13, 2012 10:11 am
Al, the manual says Oil change 2.5L filter change 3.2L & overhaul engine 3.7L
BanditAl
Post by BanditAl » Sun May 13, 2012 10:15 am
Thanks for that, 2500 ml, it's under the rubber bellows on the clutch cable.
Alan
KOC16
BanditAl
Post by BanditAl » Sun May 13, 2012 10:16 am
Thanks guys, knew I'd get the information here.
3.2 litres it is.
Alan
KOC16
Post by fossie » Sun May 13, 2012 6:50 pm
Al you will find that after you have added 3.25 ltrs it will look full in sight glass, however after running it you will need to add 1/2 ltr for the gearbox. It is filled through the sump but after the engine is run.
Remember there are 2 drain plugs . The one on the sump and one just behind frame by gear linkage. Don't forget that one or the fresh oil will be diluted with old oil straight away.
BanditAl
Post by BanditAl » Mon May 14, 2012 7:49 am
Fossie,
I would certainly have missed the second drain plug and wouldn't have added the extra 1/2 litre of oil for the gearbox and worried like mad where all the oil had gone.
Much appreciated.
Alan
KOC16
BanditAl
Post by BanditAl » Mon May 14, 2012 7:00 pm
All done, you were absolutely spot on Fossie, about 1/2 litre came out of the second drain point. The bike then took a full 3.25 litres and a couple of top ups after starting up.
Thanks again.
Alan
KOC16
