Genrerator Covers
Richiemouse
Genrerator Covers
After my little mishap with the non fitting clutch cover can anyone tell me if the 1100 and 1000 engines have the same genny cover? The one I want to buy is alledgedly off an 1100 and is stamped "4920 A" but my 1000 one is stamped "4930 B", which makes me think there is a difference and it might not fit
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Re: Genrerator Covers
Hi mate, it's a trickey bugger someone told me the 750 one fits the 1000. where the alternator fits and is mounted via three screws, that's the difference. the alternotor slides onto a tight fitting ring, measure yours, the 1100sz is 36mm I think, bloody hell I new it of the top of my head, any way cheeck that. also if you fit the wrong one a oil feed is blocked.
FBJ
FBJ
Richiemouse
Thanks John, I had a feeling in the back of my mind that it was important to get the right one.
- KeKat
- Has thanked: 3 times
- Been thanked: 44 times
Hi
The 4920? one fits:-
1980 GS1100-LT CRANKCASE COVER
1980 GS1100E CRANKCASE COVER
1981 GS1100E CRANKCASE COVER
The 4930? one fits GSX1000/1100 SZ. This according to the parts list.
KEITH
KEITH
Keith KOC 355
1982 Suzuki GSX1000SZ
1991 Ducati 900SS
1996 Kawasaki ZZR600
2003 Transalp
2004 MV Agusta brutale F4
2003 Cagiva xtra raptor 1000
2012 Triumph Tiger 800
2019 Suzuki GSX-S 1000S
1991 Ducati 900SS
2003 Transalp
Richiemouse
Hi keith, thanks. Where did you get that info? I know you can look on individual bikes fiches but is there a reverse look up facility anywhere? i.e. here is a part No., what bikes does it fit?
- KeKat
Hi
I have the parts lists for the 1000 and 1100 Kats.
If you type the Suzuki part number into Google, it will give a lot of american Suzuki parts dealers, who have online parts lists and diagrams.
Keith KOC 355
1991 Ducati 900SS
2003 Transalp
1991 Ducati 900SS
2003 Transalp
There is also a piece of software somewhere that tells you what parts are interchangeable between bikes. Think Russ has it .
Richiemouse
I know about them and they're OK for looking up parts for a specific bike or finding a part if you know it's full number but the 4903B that is stamped on the cover is only a bit of the number, it's full number is 11351-49300 the B doesn't even come into it although it must have some meaning.
b for black, same physical part as without the b, but the b means its painted so it matches the sd type black engine.
Richiemouse
Strange, the one on my engine doesn't look like it was ever painted, it looks a mess right enough but an original mess.
