Rotten eggs
Posted: Mon Dec 05, 2011 3:35 pm
by outrage
As i just found out, rotten eggs are what your battery smells like when its frying. I thought i might have run over something and it got stuck the the exhaust but after close inspection i found my battery to be completely dry.
After recently replacing the stator and changing the Reg/Rec wiring so it does not go through the loom the battery was fine. Could it be over charging?
Re: Rotten eggs
Posted: Mon Dec 05, 2011 3:54 pm
by bobster
Sounds like it's over charging to me................have you checked the battery voltage when the bikes running at 6000rpm?
If so what sort of voltage DC is it putting out?
Re: Rotten eggs
Posted: Mon Dec 05, 2011 4:18 pm
by outrage
I'd not got around to doing any testing yet but i assumed it was over charging. Ive done about 700 miles since i changed the stator and shortly after i did notice some small traces of battery acid on the swingarm but i put this down to when i had to lay it over on the right side.
Anyway seeing as the battery is dry and probably fooked i'll wait till i top it up with fresh acid before i do any running.
I didnt do any testing after i put the new stator in either. Didnt think about it at all.
Re: Rotten eggs
Posted: Sun Dec 18, 2011 4:08 pm
by outrage
I finally got around to doing some testing and it seems the battery is getting about 22 volts at normal idle in both wiring configurations of through the loom and by passing it and going straight to the reg/rec. I will be ringing Electrex to see waht they can suggest but i thought i would trow it up in here too and see what comes of it.
Re: Rotten eggs
Posted: Sun Dec 18, 2011 10:48 pm
reg rec is fucked if its getting 22vdc
Re: Rotten eggs
Posted: Tue Dec 20, 2011 7:41 pm
by outrage
Yeah i guessed as much
Re: Rotten eggs
Posted: Wed Dec 21, 2011 10:42 am
by barryr
On the upside though you could probably jump-start a truck!!
