Cold start problem on Kat 400 ssn
Posted: Mon Oct 31, 2011 11:45 am
Hi lads,
I am driving arround since June on the bike and it is going to pretty ok as far as I can tell
I have done about 3000 km, I use it to go to work and back about 40km a day at the moment.
On time to time, the cold start does not work, I have to use some easy start to get her started.
Basically most of the time it is ok, hit the button start then I have to accelerate gently for a while, and then I go and it is all fine.
But sometime I hit the button, it start but as soon as I accelerate the bike cut off, and then nothing to do to put her back on except add some easy start and she fire no problem.
I have 4 new plugs, new air filter with air fit club custom on, 4 in 1 Scorpion can on.
I never use the choke, I try few time but it did not seems to help.
I which to get it started a bit better. So any idea welcome.
It might have happen to me about 10 times over the last 3000km which is not often but still it is getting me when it happen.
It also does not happen in the morning when I get the bike outside the garage. But when I leave work, the bike is park in a wind place which I would increase the cold start issue.
I have also notice that the bike as a problem to run smoothely when cold I have to rev it otherwise it does stall.
It look to me that all those problem could get sorted if it was running a bit more rich, but I am not sure.
What do you reckon?
I am open to all suggestion obviously.
What do you reckon?
