Petrol tap gaskets
Petrol tap gaskets
Post by callyboy » Wed Jan 12, 2011 9:05 pm
Have to swap over my petrol tap onto another tank and was wondering if there is a cheaper way to do the gaskets than the £15 odd quid the kits seem to cost. Not a huge amount, but its all adding up :( is there a petrol friendly liquid gasket ?
Cold Snail
Re: Petrol tap gaskets
Post by Cold Snail » Wed Jan 12, 2011 9:28 pm
Be gentle and you wont need gaskets.
Post by callyboy » Wed Jan 12, 2011 9:42 pm
Watcha Paul.The small ones that were on the two bolt holes just fell apart. The large one that runs round the outside looks ok. albeit a bit flat and hard( as opposed to rounded and soft !!!).
Post by bobster » Wed Jan 12, 2011 10:02 pm
Pete and gentle in the same sentence! Thats a new un!
Drop me a PM with your address and I will send you some dowty seals for the 2 bolts.
Try boiling the larger main tap seal in Boiling water to make it more supple!
Oh and Dont use gasket sealant m8!
Post by bobster » Sun Jan 16, 2011 5:24 pm
Here you go Pete!
http://cgi.ebay.co.uk/SUZUKI-GS-1000-85 ... 3364280548" onclick="window.open(this.href);return false;
Post by callyboy » Sun Jan 16, 2011 7:10 pm
Cheers bobster.
Not quite the same as mine. Mine dont have the cross connection bits. just straight seal all way around.
bit like this:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... _500wt_922" onclick="window.open(this.href);return false;
Thanks anyway mate.
Post by johnr » Mon Jan 17, 2011 5:39 pm
green hermetite, seals petrol taps and doesnt get disolved. just let it dry before filling the tank ive used it on tank seals and also carb float bowl rubbers.
Post by callyboy » Mon Jan 17, 2011 6:29 pm
Watcha John, cheers for that info mate. I have bought some Loctite lock and seal for the bolt threads(couple of quid). Some dowty are being sent from bobster (unless he's forgot !!) . Will get some of that green hermetite as well.
Post by bobster » Tue Jan 18, 2011 7:34 am
Seals are in the post m8....i couldnt find any 6mm ones so have put 1/4" ones in the package..........they are slightly bigger but should still do the job!
"some people call me the space cowboy"........................"some call me the gangster of lurve" :lol:
Post by callyboy » Tue Jan 18, 2011 8:04 am
some people call me Maurice- Whaaaaa whaaaar :)
Cheers Bobster.
PS - Hermetite have gone bust ?
