Fueling issue
Re: Fueling issue
Post by Smallkat » Sat Aug 17, 2024 1:12 pm
I know this isn't your problem, but always make sure you use the correct hose for the vacuum hose. Suzuki use a thick-wall double skinned pipe for the vacuum, presumably to prevent collapse.
Walters
Been thanked: 4 times
Re: Fueling issue
Post by Walters » Sat Aug 24, 2024 9:45 am
Problem solved ! the metal prong had been mangled & was the cause of the stiff tap operation, new original spec tap from Ebay & the problems solved.
Appreciate the info , I’d never have know the prong should have been present without it 👍
Re: Fueling issue
Post by Uncle Bob » Sat Aug 24, 2024 10:10 am
Well done, glad you have it sorted.
