I’m using Conti Classic Attacks, which are a zero degree belted radial.
I using the Suzuki recommended pressures and the handling is great.
Tyre pressures
- Has thanked: 128 times
- Been thanked: 269 times
Re: Tyre pressures
GSF34058
- Has thanked: 32 times
- Been thanked: 60 times
Re: Tyre pressures
I am currently running Bridgestone Battlax BT 46 front and rear. I have always used the tyre pressures listed in the Owner's Manual. I have them written on the garage wall because I can never remember what they are!
Front, solo, normal riding / continuous high speed riding 24/28 psi.
Front, 2 up, normal riding / continuous high speed riding 28/32 psi.
Rear, solo, normal riding / continuous high speed riding 28/36 psi.
Rear, 2 up, normal riding / continuous high speed riding 36/42 psi.
David.
David.
