GSX1100SD rocker cover gasket
- Been thanked: 343 times
Re: GSX1100SD rocker cover gasket
if its only 16 bolt, then its likely to be an es/pop up type engine.
- Has thanked: 187 times
- Been thanked: 738 times
The pop up is a rubber jobbie.
Wemoto will supply Athena even if you want a vesrah which is better , it depends what's in stock.
- Has thanked: 128 times
- Been thanked: 269 times
The Cometic gasket does not fully encircle the 4 bolts at either end of the cover that are adjacent to the spark plug “slots”. If that makes sense
