Idle adjuster
Re: Idle adjuster
Post by pookie » Thu Feb 12, 2015 3:09 pm
Have you fully charged the battery? after spinning the motor over trying to start the bike the battery may have lost some ooomph, its worth checking 'cos its happened to mine.
Re: Idle adjuster
Post by johnr » Thu Feb 12, 2015 7:05 pm
easy start!
Been thanked: 198 times
Re: Idle adjuster
Post by Pedda » Thu Feb 12, 2015 7:11 pm
Have a look at the connectors ingition wise. Bet there's one gone loose.
May also be a strange coincidance and that li'l rugrat is innocent indeed.
Re: Idle adjuster
Post by fossie » Thu Feb 12, 2015 10:27 pm
As pookie says the water cooled range fitted with sealed for life batteries, won't start if hand battery is not tip top due to cdi settings.
Kat_mad_x2
Re: Idle adjuster
Post by Kat_mad_x2 » Mon Mar 16, 2015 10:31 am
Yeh battery is fine I have it on a trickle charger all winter and it's sitting at one 13. Even with battery pack on still nothing.....
She tries to start for like half a second But then nothing :s
Pedd what connections?
Gsx 1100s 1983
Gsx 400s 1992
Re: Idle adjuster
Post by Pedda » Mon Mar 16, 2015 4:33 pm
Kat_mad_x2 wrote: Pedd what connections?
I mean all the plugs in the loom ignitionwise, be it from the pointers or coils or cdi.
You're saying it wants to start but just not enough to run?
If so, that sounds like poor earth somewhere.
prothed
Been thanked: 5 times
Re: Idle adjuster
Post by prothed » Tue Mar 17, 2015 3:11 pm
Late to the party here - but have any of the plug leads been disturbed?
Kat_mad_x2
Re: Idle adjuster
Post by Kat_mad_x2 » Tue Mar 17, 2015 6:57 pm
I took the two outside plug out to see if there is a spark and both are getting spark :(
Middle ones I didn't check look a but awkward to get at but will try tonight
Gsx 1100s 1983
Gsx 400s 1992
SamK
Has thanked: 11 times
Been thanked: 64 times
Re: Idle adjuster
Post by SamK » Tue Mar 17, 2015 10:15 pm
Which coil feeds which cylinders?
I know the popup has one for 1 & 4 and the other for 2 & 3
I had 1 coil pack in but the bike still started and ticked over on 2 cylinders.
Re: Idle adjuster
Post by fossie » Tue Mar 17, 2015 10:38 pm
The 400 are prone to right coils going down, also cdi issues ,aswell as if the battery ampage not voltage is suspect the cdi won't allow it to start. Add in cut out switches on side stand. And clutch on some ......
This is before the fuel side .......which includes the choke cable not pulling the bar out all the way if it is not routed correctly.
