If anyone has a set of VM32’s close to hand I could do with some dimensions particularly the engine side bore. Photos as well would be fantastic!
I have a set of VM’s that were supposed to be the correct ones, but I’m not convinced. They measure 36mm diameter on the engine side.
I have a set of VM33 smoothbores that have been cleaned up and may use them instead, or do I sort out a set TM34’s
Would prefer to run with a full airbox and obviously a 4-1. I want the Kat to be useable on normal roads.
