I have changed the rear brake line to a braided one, but am missing 1 of the rubbers that help it clip to the swingarm.
These aren't a Suzuki part number as they come with the brake line itself.
Anyone have one or know other bikes that might have them as I could possibly look for a secondhand line on Ebay with one attached to. They are flat one side that goes against the swingarm.
Marked in Yellow on the parts image below.
Rear Brake line mounting rubbers GSX400SSN
- sparki
- Committee Member
- Has thanked: 80 times
- Been thanked: 72 times
Re: Rear Brake line mounting rubbers GSX400SSN
call venhill or hel as they use the same on their braided lines... maybe they'd sell/send you one?
- Has thanked: 660 times
- Been thanked: 250 times
Thanks for looking Blix.Blix wrote:Got this if it’s any use, obviously it’s been cut but that could be glued & hidden.
That looks quite a bit different but could be cut around I guess. If I can't get the same though, I'll probably use some old inner tube I have, cut and wrapped around it.
It was a Hel line I replaced it with, but it only had one (I think it was 1 or none) on it. I'll go for some old inner-tube wrapped around it probably.sparki wrote:call venhill or hel as they use the same on their braided lines... maybe they'd sell/send you one?
Having a tidy up in the garage and found some rubber pipe with thick 3mm walls, that fitted the job perfectly, once cut to size.
