Compression
Re: Compression
Post by callyboy » Sun Oct 11, 2015 7:37 pm
New rings and maybe a hone as well?
jmac
Been thanked: 84 times
Re: Compression
Post by jmac » Mon Oct 12, 2015 11:49 am
Oh well, I suppose it will keep me out of the pub for a while..............but there again.
Re: Compression
Post by johnr » Mon Oct 12, 2015 7:59 pm
has fossie not got any engine bits?
jmac
compression.....the sequal
Post by jmac » Wed Oct 14, 2015 10:53 am
Engine in bits, rings seized in position, but I think I can free them off. However, I noticedthat th
Engine in bits, rings seized up Looking for new set. However, I noticed there was a slight sideways "rocking " movement in all for con rods, but could not feel any up and down movement.
Should I be worried?
Re: Compression
Post by bobster » Wed Oct 14, 2015 10:57 am
Only when it goes bang.............slight sideways movement is normal....Movement up and down isnt.
jmac
Re: Compression
Post by jmac » Wed Oct 14, 2015 6:10 pm
Cheers bobs.
skelly
Has thanked: 2 times
Been thanked: 2 times
Re: Compression
Post by skelly » Fri Nov 18, 2016 4:41 pm
Crank it over with the plugs out to blow all the shit out the cylinders.
Be carefull, it gets messy and can catch fire if the plug leads decide to spark while doing this (don't ask me how I know) , best to disconnect the ECU or crank pickup connector first.
Do a comp test and check the readings.
If they are low, stick a couple of squirts of oil down the bores and do it again, if the results improve considerably then you have a piston ring issue.
Then you have choices but it will involve a top end strip.
Skel.
Has thanked: 80 times
Been thanked: 72 times
Re: Compression
Post by sparki » Fri Nov 18, 2016 7:03 pm
he may have moved on bud... that post was 13 months ago ;)
KOCUK - 241
