Wiring
Has thanked: 120 times
Re: Wiring
Post by Kryten » Sat Jan 24, 2015 3:30 pm
Doesn't the genny lead pop out into the starter motor well and then run back to the rear of the engine alongside the starter motor feed and the neutral indicator wire. Tucks into a cable run above the front sprocket
Has thanked: 80 times
Been thanked: 72 times
Re: Wiring
Post by sparki » Sat Jan 24, 2015 10:35 pm
no it doesn't;... thats a drain hole ;) - the benny wires go around the starter motor and out of the same exit as the starter cable ;)
KOCUK - 241
Re: Wiring
Post by bobster » Sun Jan 25, 2015 12:22 am
What he said........
lomsavage
Has thanked: 3 times
Been thanked: 28 times
Re: Wiring
Post by lomsavage » Sun Jan 25, 2015 8:22 am
Benny wires
do they have a wooly hat on or something ??
Hello from H
Re: Wiring
Post by bobster » Sun Jan 25, 2015 7:06 pm
My Kat came in boxes so I just messed with it until it looked correct. Keep on messing ;-)
Re: Wiring
Post by sparki » Sun Jan 25, 2015 8:13 pm
^^ where ever it fits best and looks tidiest... you gonna get rid of the crappy connector block things are nt ya! ;)
KOCUK - 241
Re: Wiring
Post by bobster » Mon Jan 26, 2015 4:11 am
Mick
what I would say is that: take the genny wires over the top of the engine mounting spacer through the gap, then you know it wont drop down and get mashed by the chain....you could even cable tie it to the spacer to make doubley sure ....Looking really good by the way! Hope to see it finished in the next 2 or 3 years ;-)
Re: Wiring
Post by Kryten » Mon Jan 26, 2015 1:19 pm
I routed the wires over the top of the engine mounting spacer, as Bobster said. It was a case of trying different routes until I was happy. The diagrams in the manuals aren't that clear but they then sit behind the frame tube and will be clear of the chain run
Been thanked: 115 times
Re: Wiring
Post by katmarch » Tue Jan 27, 2015 1:56 pm
Blix wrote:2 to 3 years.......lets not get carried away m8
The plan is to get it on the road after H has completed one of his projects ;)
Like Bob said then head towards the battery box, think mine has a tin clip attached to hold the wires in. It then joins up in the rubber boot at the rear of the battery box.
Anyway you'll have a decade or 2 to get it right if your waiting for H to finish one of his :lol:
looking good though, where's all the road grim?
