1100 engine into 750s2 electrical bits / wiring differences?
Katgeezer
Has thanked: 6 times
Been thanked: 8 times
Re: 1100 engine into 750s2 electrical bits / wiring differen
Post by Katgeezer » Sun Nov 13, 2011 10:42 am
You might need the cdi but I'm not 100% on that. Think that's about it.
Has thanked: 119 times
Post by Kryten » Sun Nov 13, 2011 7:01 pm
Katgeezer wrote:You might need the cdi but I'm not 100% on that. Think that's about it.
Apparently not required, as the 750 is alledgedly the same. But you might as well put a Dyna system in at the same time. Just a bit of wiring mods to connect the Tacho.
About the only other wiring difference is the use of Self Cancelling Indicators some of the 1100's
