XN85 - Bad vibration at around 3000rpm
FBJ
- Has thanked: 5 times
- Been thanked: 31 times
Re: XN85 - Bad vibration at around 3000rpm
Did u powder coat the engine mounts? Re tighten ur mounts
FBJ
You need to remove the mounts and cut the coating of where the mating faces meet
- Pedda
- Has thanked: 53 times
- Been thanked: 198 times
- Pedda
I bet you're able to do four of'em, cally.callyboy wrote:I can only change a spark plug![]()
Tim,
as you say everything's got balanced, I take it you matched the pistons for same wheight, too?
In case you don't have any suspects enginewise, do you have proper bar end weights? Not the hip alloy or even carbon ones, but solid steel? They might help a bit then.
Russbusa
Best ignore that boost guage, stick a "t" piece in line and run a 1 bar guage to check what the actual boost is. is the waste gate stuck open ? Mine was stuck shut at mold this year and made the boost keep building until the ignition cuts @12psi.
As for your vibration. . . . .not got a clue as mines smooth all the way through the rev range,
