did you come across those lil rubber bungs for the forward two mounts of the tail fairing at all?
we still need a small list of the other missing bits.... was bobster looking for some cap screw push on plastic covers.... and fork leg cap rubbers spring to mind..... a couple of rear footpef mounting bolts (the ones used were shimmed with a nut to reduced the collared area i recall)... front footpeg rubbers were ripped i think, bar end weights needed, clutch lever replacing with a black one or straightening and painting black, fuel tap needs sealing properly cos it's gonna leak, chain needed,.... can't think of more but likely is
maybe this needs to go in the "bits needed" thread
