Could be a bargain.
- Has thanked: 148 times
- Been thanked: 671 times
Could be a bargain.
https://www.ebay.co.uk/itm/Suzuki-Katan ... SwMPxe7jB0
We have spare seats in the club.
Keys are not a real issue if you take the helmet lock off and take it a proper locksmith he can cut a key for it ...viola a key for the ignition . The fuel cap will probably just undo anyway... If it does then this can be used in stead of the helmet lock.
- lomsavage
- Has thanked: 3 times
- Been thanked: 28 times
Re: Could be a bargain.
went over today to give this a look (Bradford way)
on the down side quite tatty, rear brake needs attention, choke not connected/working, discs a bit worn (but not too bad)
plus side front brake seems ok/good pressure forks/seals seem ok suspension seems ok, chain ok (but no chainguard), told pop up works
all in all not a great deal to do to get roadworthy though a lot more required to get tidy/mint
Above is all assuming it actually runs and electrics are OK as no key so can't start/check anything
On the key front it is apparently a 1 key bike and the tank filler is unlocked, so as Fossie states not a big issue. This does however raise the question as it's a simple fix why hasn't previous owner done this to ensure a better sale price, something to hide ?
as with all used bikes (I suppose) caveat emptor
Hello from H
No Kats and unlikely to ever have one again (hey ho, that is what life throws at us)
- Has thanked: 97 times
- Been thanked: 228 times
Blimey! Looking at that seat; the dog must have been really angry!
Probably foaming at the mouth.........
<Runs and hides>
<Runs and hides>
- lomsavage
Hello from H
- lomsavage
Also just checked DVLA website,
contrary to ebay listing (off road for 4 years), last MOT expired October 2012 ???
Hello from H
I've come across the key issue many times, people just don't think past the ignition key opens everything else.....instead the SAME KEY ..and of course getting a spare key cut nowadays will take you to Timpson et al who are not locksmiths .
- lomsavage
(just) over £1600, Ok ish price but too rich for me
Hello from H
