400 speedo cable
400 speedo cable
I replaced my snapped speedo cable with one from the GSF400 bandit. The drive ends are correct and the length is just slightly too long, but better than too short. The only slight fly in the ointment is that at the speedo end, it doen't have the extended screw-in bit, so you have to tighten it with a pair of needle nose pliers.
Re: 400 speedo cable
Good to know Dean. Think we need a substitute database for the 250/400 katana so any duplicate or similar parts can be swapped without any headaches.
Just thinking about this the other day. The better thing to do would be to keep the old outer, with its correct end fittings and replace the inner only!
