Rear mudguard
Rear mudguard
Hi has anyone got the metal section of the rear mudguard lying around. If they have are they willing to part with it?
Re: Rear mudguard
You’ve got me there. I assumed from the parts diagram the the part was common to all the pop ups. The rego docs just have it as a 1984 white Suzuki Katana GSX750 the chassis is a GR71D. Hope that helps.
- Been thanked: 715 times
Re: Rear mudguard
Ah there you go yep there is only one part number for the pop up ...( which at this point we were only assuming
But yep same as GSX 750 Es ...I may have one but your not really local if I remember
Re: Rear mudguard
Hi Fossie thanks for the reply. I have gone back through various models and have found some better pictures of the part. The ES has a different part number but on closer looking has the same base structure but has two extra lugs welded on. This being the case I now have a new avenue to pursue. Again thanks for replying. By the way starting my own collection 4 pop ups two are immaculate plus the one I’m building.
Cheers hope the summer is good it is wet here (understatement) sheep need life jackets.
