Hi, decided to delve into my box of bits again realising I’ve taken on more than I should!
Does anyone have any detailed photos of their wiring loom as fixed to the frame and attached to the various components?
I cannot see a second connector from the loom to connect to the CDI. Any ideas. Problem is various bits are missing making it harder to establish what’s what.
I see photos in the gallery of someone building their pop up from scratch. Hope you can help. Thanks
Wiring loom woes help needed
- Has thanked: 128 times
- Been thanked: 269 times
Re: Wiring loom woes help needed
Hi Bertie
I have pinged you a pm.
I think you are looking for the connector to the pick-ups on the engine, the ones my brother on his ES smeared into some Belgian tarmac back in the dim and distant past.
Will have a look next week when I'm home.....
.......unless a Pop Up owner on here can help out.
- Has thanked: 187 times
- Been thanked: 738 times
Yep ignition looking for a connector with green and blue wires I believe...shouldn't be hard to suss , but I will take a picture in the week possible We'd news day when I MOT the hyprocyte Kat.
