Greetings from South Yorkshire UK
Hi, I'm Chris from Rotherham, South Yorks & I'm currently contemplating swapping my 1975 Suzuki GT550M for a 1984 GSX1100S Katana. Is there anything that I particularly need to look out for, bearing in mind the bike has supposedly had a full restoration a year or two back & has not run for a year or so. I know that it needs a few bit's & bobs doing to it but they are mostly cosmetic. Greatful for any help.
- Has thanked: 53 times
- Been thanked: 201 times
Re: Greetings from South Yorkshire UK
Always difficult to judge how the pre-owner understands a full restauration, I think. You might notice a clutch basket rattle on tickover, disappearing when you pull the clutch lever. Quite common noise with mileages from about 40.000 km onwards. Should not disturb you.
So is 5th gear whining noise.
Ah, and welcome here.
Thanks, I'll bear them in mind when I get to hear it running, hopefully later this week.
- Has thanked: 122 times
Welcome aboard!
Hey up pal fellow South Yorkshire'n 'ere, though on'tuther side'o hills na..
Truth is owt that's been fully restored is a bit of gamble unless you know the chap who's done it and trust him ..That's not to say anything has not been done correctly , but it could end up missed matched model parts. That said in truth 40 years on it's very likely anyway .
If it's been stood for a long while the carbs may need cleaning if E10 was left in the tank and the carbs not drained ..Check the charging is 14.5 v with all lights on at 6000 rpm .. Many restorations have powder coated frames and old GS's need a very good earth points but people don't always clean these points off well enough .
You say 1984 so is it an import .?
It was registered in May '84 so possibly an '83 that was left on the shelf. It's the one that was on eBay with the shortie pipe, all silver. I'm seriously considering part exing my GT550 for it.
The beauty of the pre 2000 registrations means a bike registered from 1 August in 1983 will have the same prefix as one registered on 31 July the following year.
After 2000 imports were given a prefix to co incide with date of first reg in the original country .. hence we have bikes registered before the release date of that model ..
However the bike in question was registered in Nottingham so unlikely to be an import .. The wheels and pegs are SD so later model 83-84 as suggested . But resprayed in the iconic colour of silver of earlier model.
As for worth only you can decide what it's worth to you ..
