checking Alternator .
Post by fossie » Mon Aug 19, 2024 11:50 pm
Just did a quick continuity check on a 650 alternator wires and got a bleep when I joined , 1 with another but not from the others , , but not when I put one probe to earth ,
My memory must be going , so should I have a bleep across all 3 or No bleep, eitherway these windings are failing to produce the 14.5v they should and yes it could be reg/rec...but obviously the windings are suspect .
This is on the 650 I lent to Jmac and have only just found the time to get round to checking it out ...
Has thanked: 122 times
Re: checking Alternator .
Post by Kryten » Tue Aug 20, 2024 8:21 pm
Continuity between phases should be the same, or a beep!
So 1-2, 1-3 & 2-3 should all be the same.
No continuity phase to earth, that’s a phase shorting to earth if you do….
Ideally you would use a insulation tester/megger, but a machine that goes beep should be adequate :D :D
Post by fossie » Wed Aug 21, 2024 12:25 am
cheers , yep bleep 2-3 ..no bleep on others .. oddly the thing charges 3/4 strength as said...but it is wired direct , not through lighting circuit.
