VM32 for Kat 1000
Has thanked: 122 times
VM32 for Kat 1000
Post by Kryten » Wed Aug 30, 2023 8:07 pm
Trying to work out what carbs I have for the collection of bits that will form the basis of my Kat Thou.
If anyone has a set of VM32’s close to hand I could do with some dimensions particularly the engine side bore. Photos as well would be fantastic!
I have a set of VM’s that were supposed to be the correct ones, but I’m not convinced. They measure 36mm diameter on the engine side.
I have a set of VM33 smoothbores that have been cleaned up and may use them instead, or do I sort out a set TM34’s
Would prefer to run with a full airbox and obviously a 4-1. I want the Kat to be useable on normal roads.
Been thanked: 62 times
Re: VM32 for Kat 1000
Post by stockcar » Thu Aug 31, 2023 7:18 pm
Carbs are all wrapped up but external measurements on air box side are 55mm and 40mm or engine side
Post by Kryten » Fri Sep 01, 2023 1:24 pm
Cheers for those measurements. My VM's that I have measure at 36mm internal on the engine side. So I assume they're VM36's.
Post by johnr » Sat Sep 02, 2023 7:35 pm
there were quite a few vm32 sets that were bored out to something like 35 or 36mm for racing, but im not sure on the exact details.
