for an SZ
Has anyone on here fitted a swinging arm from a Krash-a-thrashi ZRX1100 to the Kat frame? Or seen it done..
That's the twin shock retro jobbie. It seems to be close enough but the pivot end is about 15mm wider than the standard at 225mm
Replacement swinging arm
- Has thanked: 122 times
- Has thanked: 53 times
- Been thanked: 201 times
Re: Replacement swinging arm
Got such a swinger in the basement if you need measurements. For serious approach you have to reposition the lower shock mounts otherwise it'll look a bit x-legged. And yes, narrowing the pivot is a given.
